I am skp to citygml Convert, But Geo Location Error
  • Oct 18, 2018 2:35 PM UTC
  • 35 views
I use this https://hub.safe.com/templates/citygml-create-simple-city Sample, But I don't Know mean offset paramerter set EPSG:31467 are x:,y:.
I am set Reader skp set EPSG:31467, but how did set x,y?
so, I set Offsetter x,y, but i want position and model is vary different position!
How did i skp convert citygml?
chrisatsafe
Hi @sayassong56,
In order to set the X/Y offset, you will need to add an Offsetter Transformer to the workspace. Place the Offsetter after the SimpleCity Reader and enter the X/Y offset values that are provided in the Source Data Description (optional) section of the Workspace Description annotation.
Hope this helps.
- Chris
citygml-create-simple-city.fmwt
