I am reading a csv file with easting and northing columns (British National Grid), however FME seems to be automatically changing them to Lat Long even though I have the projection set as EPSG:27700 or if I don't set a projection at all.
  • Apr 28, 2023 9:04 AM UTC
  • 135 views
ruth_h
Forum|alt.badge.img+4
How do I stop it changing the entries in those fields so I can create points in the correct location please?
daveatsafe
Forum|alt.badge.img+24
  • Apr 28, 2023 10:48 PM UTC
Hi @ruth_h​,
Would you mind sharing a small section of that CSV file (perhaps two or three lines, plus the header)? It would be helpful to see your workspace as well.
Forum|alt.badge.img+54
  • May 2, 2023 10:51 AM UTC
Check the Attribute Definition under the csv reader parameters, i suspect they are being incorrectly interpreted as time. Change the option to manual and you can then choose the type as x-coordinate and y-coordinateimage
ruth_h
  • May 2, 2023 11:00 AM UTC
Thank you both for your replies. ebygomm - you are right, that's exactly it. It was annoying me so much but that fixes it. Thanks very much.
