I am new to fme. I have a citygml file of buildings with attribute codes such as 2100, 3400. The definition of this code is in another XML file so how do I setup the workbench so that the citygml file can access the attribute values from the XML f
  • Oct 30, 2020 1:52 AM UTC
  • 22 views
I am new to fme. I have a citygml file of buildings with attribute codes such as 2100, 3400. The definition of this code is in another XML file so how do I setup the workbench so that the citygml file can access the attribute values from the XML file?
caracadrian
Forum|alt.badge.img+23
  • Oct 30, 2020 5:48 AM UTC
Use the FeatureMerger transformer to merge the attribute values from XML to your citygml data.
Use the buildings codes from citygml as a requestor and the attribute that contains those codes in xml as a supplier.
davtorgh
Forum|alt.badge.img+12
  • Oct 30, 2020 2:11 PM UTC
Hi @dennis​ ,
an alternative way to the one suggested by caracadrian could be use a FeatureJoiner (which performs faster on simple attribute based joins). If you want to lear more on Joins, see this article.
Hope that helps!
