HTTP Error Code: 413 : '' 'The page was not displayed because the request entity is too large'
  • Apr 3, 2026 12:42 PM UTC
  • 191 views
sanja
Hello, I’m trying to upload attachments from AGOL to AGOL using process described in the article How to Use the ArcGISAttachmentConnector, I’m on FME workbench 2026.1
On small test this runs fine, but when I start testing actual production feature services, I get error
The ArcGIS REST API returned an error: HTTP Error Code: 413 : '' Message Code . Further details: 'The page was not displayed because the request entity is too large
I have tried by lowering the number of records per request in the readers to 500 and 300 but it failed.
Is there a workaround for this? I do read all the records in; none are filtered (as I’m new to FME I stuck to the article). Would skipping the empty attachment records help? I feel it’s case where the mov files were attached that the upload failed, but I’m not 100% sure.
sanja
  • Apr 8, 2026 9:58 AM UTC
Turns out the attachment type is not the issue, it’s the size. The flow fails every time it’s over 4Mb. To bypass this I have setup filters for this in order to download instances of bigger MOV files for analysis and the created an excel with corelating info on these.
desiree_at_safe
Forum|alt.badge.img+24
​@sanja! Thanks for bringing this up!! It definitely sounds like we should dig into it a bit more and see if we can improve this limitation.
 If you can, please submit a ticket
When submitting your ticket, please provide the following (if available):
- Details about the environment used (e.g. platform and OS version, FME Flow deployment, any other dependencies, etc.)
- Any relevant log files (e.g. translation logs, job logs, fmeserver.log, etc.)
- Any relevant screenshots (e.g. errors, configurations, etc.)
- Please provide a sample of the source data used in your workspace
- The workspace (or sample workspace) that you are encountering issues with. Please be sure to include any required data or custom transformers needed. If, possible please send this as a template (.fmwt).
