HTMLReportGenerator: bad vertical table alignment when using "group by".
  • Sep 16, 2020 4:01 PM UTC
  • 60 views
davtorgh
Forum|alt.badge.img+12
Hi everybody,
I built a report composed of some tables using the "group by" parameter to split the rows in groups. Despite the data structure and types are the same (obviously), there is a bad vertical alignement beetween the tables (see attached screenshot).
screenshot
Any suggestion is welcome!
Thanks
anhphuongt
I wonder if you can merge all the tables into one and send it to the HTMLReportGenerator.
Otherwise, you'll have to use CustomHTML to set the column's width manually.
davtorgh
  • Sep 21, 2020 3:45 PM UTC
Thank for your answer @Anh Phuong Tran​ ,
but i used the group by parameter just to split the table in sub-tables to keep the report clear.
Bye
