HTML Report Generator - Time Output Problem
  • Jan 18, 2022 9:08 AM UTC
  • 124 views
Hello everyone,
So I would like to generate a HTML report by using "HTML Report Generator".
For the final product, I would like to generate the report with the "current time" on the HTML page.
This is what I write in the text editor:
 KE Indoor run on @DateTimeFormat(@DateTimeNow(local),ISO)
The output is:
 KE Indoor run on 2022-01-18T16:58:52.1754106+08:00
However, this is what I want for the result:
 KE Indoor run on 2022-01-18 16:58:52
May I ask how can I fix the problem?
Thank you in advance.
Best answer by geomancer
KE Indoor run on @Substring(@DateTimeFormat(@DateTimeNow(local),%Y-%m-%d %H:$M:$S),0,19)
or
KE Indoor run on @Substring(@DateTimeFormat(@DateTimeNow(local),%Y-%m-%d %T),0,19)
$S (for seconds) or $T (equal to %H:%M:%S) always includes partial seconds, so you have to remove those.
jr2
  • Jan 18, 2022 12:52 PM UTC
Hi, just add the format you would like to have: Ex: @DateTimeFormat(@DateTimeNow(),%B %d %Y)
See all format :
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/!Transformer_Parameters/Date-Time-Functions.htm
geomancer
Forum|alt.badge.img+71
  • Jan 18, 2022 6:12 PM UTC
or
See all format :
Thank you very much!
or
This is exactly what I want.  Thank you so much!
