How to zip a CSV-File inside an attribute?
  • Apr 3, 2020 3:28 PM UTC
  • 95 views
My duty is to read multiple CSV-Files my means of HTTPCaller from an online source into an attribute each, subsequently zip the CSV-file inside the very attributes, and finally write the binary attribute content (zipped CSV) to a PostgreSQL bytea-Attribute.
I know how to read the HTTP source and write into the bytea destination attribute.
QUESTION: How am I to zip a CSV-file inside a binary BLOB FeatureType attribute within the FME Desktop Workspace.
Hint: I tried to use the ZipArchiver, but that one needs a file as source, as well as destination, but wouldn't work on attributes.
Many thanks for any effort!
  • Apr 3, 2020 3:44 PM UTC
It's not exactly what you asked for, but hopefully it can give you some ideas: https://knowledge.safe.com/questions/82001/how-to-convert-csv-data-in-a-single-attribute-to-a.html
Basically, either use the TempPathnameCreator + AttributeFileWriter to write the CSV contents to file before zipping it with the ZipArchiver and reading it back with the AttributeFileReader, or using Python to do the same thing in-place.
