How to write metadata to a fileGDB?
  • Feb 23, 2024 2:04 AM UTC
  • 10 replies
  • 209 views
nicholas
Forum|alt.badge.img+14
I have a dataset stored in Oracle Spatial, and I have metadata stored as an xml file (the xml is generated by ESRI software).
I want to Write a fileGDB where the metadata is added to the feature layer.
How do I accomplish this?
nielsgerrits
Forum|alt.badge.img+67
The article Working with Geodatabase Metadata: Writing/Updating Metadata is a good point to start.
You can find these when searching the Knowledge Base.
nicholas
  • Feb 25, 2024 11:42 PM UTC
I tried that, but got an error. It failed to write the metadata
Parsing XML document 'D:\2024\02\HVRoutes\original\routes\Heavy_Vehicle_Routes.xml'
Error occurred using IXmlPropertySet2::setXml(). HRESULT = -2147215103.   File: C:\code\fme\foundation\formats\geodb2\geodbutilities.cpp   Line #: 3369
Storing feature(s) to FME feature store file `D:\2024\02\HVRoutes\v1\ExtractRoutesOpenToFileGDB_log.ffs'
...much metadata…
GEODATABASE_FILE writer: An error has occurred. Check the logfile above for details
GeodatabaseRelationshipFeaturesPipeline::GeodatabaseRelationshipFeatures (SortFactory): Finished sorting a total of 0 features.
Transaction #106 rolled back. Rerun translation specifying transaction #105 for the keyword 'TRANSACTION'
Closing the Esri Geodatabase writer
nicholas
  • Feb 26, 2024 1:54 AM UTC
I am using an .xml that I have exported from ArcCatalog.
The .xml opens in Microsoft Edge fine
So, I think the xml is formatted okay
nielsgerrits
...much metadata…
Hard to say without you data, but did the sample work? If it did, you can go from there and you need to find out why your XML does not work for you. Reading XML, as it is an open format, it can be anything :)
nicholas
  • Feb 27, 2024 1:14 AM UTC
The sample did work.
I have attached the xml that I am Reading.
I exported this xml from ArcCatalog, so I am assuming that it is valid.
I also viewed the xml using Edge browser, and it was happy, so I thought that was a good test.
And I submitted the xml to an xml validator (XML Validator (w3schools.com)) and that returned no errors
And I used the XMLValidator Transformer, which it passed
My workspace copies the same transformers as the example, lacking only the XMLUpdater, as I do not need to modify the xml
I still get an error that I cannot diagnose
nielsgerrits
What is the error that you get?
Can you look at the logfile to see there are any warnings or errors?
When I run the 2021.1 sample I get the following errors:
2024-02-27 08:45:39| 0.6| 0.1|ERROR |Unable to perform any licensing related tasks. Please check your Esri ArcGIS Compatibility setting. This 64-bit version of FME requires ArcGIS Desktop along with 64-bit Background Geoprocessing; ArcGIS Pro; or ArcGIS Enterprise. Refer to this this article http://fme.ly/qua for more details
Which means I have to change the Esri ArcGIS Compatibility in the Navigator from Esri ArcMap to Esri ArcGIS Pro, as I do not use ArcMap anymore.
When I change the XML from the sample to your data, it still runs, but it won’t read anything. But this is to be expected, as the XML structure from your data differs from the sample. So you have to change the XML part to your need.
nicholas
  • Feb 27, 2024 11:16 PM UTC
This is the error
I have also attached the full log as a txt file (or would a word document be better? The txt file loses the red colour of the error lines)
nicholas
  • Feb 28, 2024 1:19 AM UTC
Yes, I do have Esri ArcGIS compatibility set to: Esri ArcGIS Pro
australgis
Forum|alt.badge.img+3
  • Sep 9, 2024 2:02 PM UTC
Did you have any answer to this error when updating a SDE metadata?
I am having the same error as you, actually. My workbench was working perfectly with FME Desktop 2021, but stopped working when we migrated to FME 2022
nicholas
  • Sep 10, 2024 1:10 AM UTC
No, I have not received an answer.
