How to write AutoCAD line types to PDF
  • Jul 12, 2017 8:41 PM UTC
  • 8 replies
  • 228 views
fmelizard
Forum|alt.badge.img+22
I need to convert dwg to pdf and one of the line styles is "- x - x - x - x". I can create different dash line but not sure I can add x in between dashes. I hear there are possibilities of either converting it to raster when writing or keep the vector form. I would love to get some idea on how to do both. Thank you!
stalknecht
  • Jul 13, 2017 3:02 PM UTC
Can you post a dwg example?
  • Jul 17, 2017 3:27 PM UTC
linetype-test-drawing-demo-bldg-2017-01-09.dwg
Please find attached sample drawing and sample PDF created from AutoCAD just show how the fence line should look like.
Discussed the option of using raster image with the team. The raster option is not a good choice. Is there any other possibilities?
stalknecht
  • Jul 18, 2017 7:23 AM UTC
Can you also share your workspace what you've done sofar?
gio
Forum|alt.badge.img+15
  • Jul 18, 2017 3:42 PM UTC
You could create a LIN file using fme. In a user folder which is added to the autocad search path. (put it in front of the standard so it gets used first)
And yes, you can use text and even shapefiles for the line pattern.
Check for instance
http://www.foresoft.com/Tutorials/linetypeautocad.htm
Or editing the standard lin file (backup original). Not best practice though.
  • Jul 20, 2017 2:25 AM UTC
Your link is talking about creating custom lines in AutoCAD, we already completed this part. I am trying to convert DWG custom lines like "-x-x-x-" to PDF.
Forum|alt.badge.img+54
  • Jul 20, 2017 8:16 AM UTC
So something like this? (I cannot see any sample pdf)
cross-hatch.pdf
spatialexjames
Forum|alt.badge.img+10
Was there ever a solution to this? (writing to a pdf using .lin CAD styles)
