How to visualize chart data using a color ramp?
  • Apr 14, 2023 1:32 PM UTC
  • 89 views
limo
Forum|alt.badge.img+8
We have generated a chart by using the transformer "HTMLReportGenerator".
As result we have something like this:
image.pngNow we wanna color each data point inside the chart differently. Something like this:
In fme I can only choose one color for the hole data atribute!
Is it piossible to create different colors for one data attribute?
Forum|alt.badge.img+54
  • Apr 14, 2023 3:23 PM UTC
It can be done, but requires fiddling with the HTML output and it's not particularly straightforward
limo
  • Apr 17, 2023 5:05 AM UTC
how did you do that?
I know that the transformer "HTMLReportGenerator" allows only one color for the data attribute!
  • Apr 17, 2023 7:39 AM UTC
If you can create a comma separated string of RGB values representing colours for each of your points, you can then use a string replacer after the report generator to do something like this
imageExample rgba attribute
"rgba(0,3,251,255)","rgba(0,1,250,255)","rgba(0,1,250,255)","rgba(0,1,250,255)","rgba(0,1,250,255)","rgba(0,1,250,255)","rgba(0,1,250,255)","rgba(2,14,240,255)","rgba(0,30,223,255)"
