How to use feature reader to read ArcGis geodatabase sde and show the content of each table
  • Apr 17, 2023 4:36 PM UTC
  • 210 views
gogopotter90
Forum|alt.badge.img+14
hello ,
how could I use feature reader to read Esri ArcGis geodatabase sde to get the content of tables .
i have tried it but the output has no content of table .
it shows me only the amount of table .
could some one explain me ,how to get the content of tables by using feature reader ?
and also show the output ports with name of each table ?
i will be thankful if someone could show me the parameters that I should consider in Festure reader .
FME 2021
nielsgerrits
Forum|alt.badge.img+67
Not sure if I understand your question, so I'll write down the steps I follow:
  • Add a Creator and a FeatureReader.
  • Connect Creator to FeatureReader.
  • Open FeatureReader Parameters.
  • Choose Format Esri Geodatabase (ArcSDE Geodb)
  • Click Parameters...
  • Select Connection File and click OK.
  • Click on Feature Types to Read (...) and select the FeatureClass you need.
  • Click OK.
  • Run workspace.
gogopotter90
  • Apr 19, 2023 3:00 PM UTC
  • Click OK.
  • Run workspace.
I have did it but I did not get the output that I expect .
what else should I have to look for .
