How to update PostgreSQL existing schema with any new data with additional columns ?
  • Jul 29, 2022 2:38 AM UTC
  • 7 replies
  • 550 views
I am new for using FME to create PostgreSQL database and having trouble updating schema or adding columns to the existing table. so to explain in detail:
1) I have different councils 3 waters pipe data which I want to add to my database
2) I have already done extracting, and transforming of data but now I want to load data coming from different councils into a single PostgreSQL database
3) So I am using FME writer format "PostgreSQL" and table (say Table1) definition as "Automatic" and ok till I have added the data from one council having 52 columns
4) Now when I am trying to add data into same postgresql database table (Table1) from other council having 79 columns in it ... my database is not accepting data from those new columns came from new council 79-52= 27 columns into my existing database table
Any comment or recommendation on this will be great!
@ppp19​ FME writers cannot perform an ALTER TABLE. To do this you can use the SQLExecutor with the appropriate ALTER TABLE statement
The SchemaScanner transformer might help you determine the new columns and help you formulate the SQL. More on SchemaScanner here and here
  • Aug 1, 2022 3:13 AM UTC
Hi @Mark Stoakes​,
Could you please help me build the SQL statement to alter the table using SQLExecutor?
My Database has say 5 columns: NetworkType, Council_ID, Population, Unique_ID and Comm_Date and new coming table has 10 columns: NetworkType, Counil_ID, Population, Unique_ID, Comm_Date, Column 1, Column 2, Column 3, Column 4 and Column 5 (Where Column 1 to 5 are new columns to add in above generated database)
I have already used SchemaScanner to get details of all new coming columns from this new table.
geomancer
Forum|alt.badge.img+71
  • Aug 1, 2022 9:07 AM UTC
Read and learn: https://www.postgresqltutorial.com/postgresql-tutorial/postgresql-add-column/
Also be VERY careful with this kind of database operations!
  • Aug 1, 2022 10:10 AM UTC
Hi @geomancer​,
this is more adding new column and data type using postgreSql …however, is there any direct transformation function available in FME…that can add such columns reading from coming new data files? …I am asking this…because I have data coming from 32 files …out of which I want to creat database ….and add just new columns data into already existing database.
geomancer
  • Aug 1, 2022 11:33 AM UTC
Hi @ppp19​ ,
Like @Mark Stoakes​ says, first use  SchemaScanners to get all information of the existing columns in the database table and the columns you want to add (you get a list attribute with all the attribute names and their data types), analyse the attributes to determine which columns you want to add, then use an SQLExecutor to add the new columns to the existing table.
Maybe something like this (untested):
Alter_Table
  • Aug 1, 2022 11:36 PM UTC
Hi @geomancer​ ,
I have reached up to FeatureJoiner transformer as you have shown in the workbench template above... However, I am stuck at the AttributeManager transformer. My question: how do you translate FME data type into PostgreSQL data type using attribute manager? Can you please tell me the formula for this?
geomancer
  • Aug 2, 2022 5:27 AM UTC
Hi @ppp19​ ,
There is no formula, you will have to figure it out yourself.
The fme_data_types are listed here, for PostgreSQL you can find them here.
So for example fme_int64: Integer data that occupies 8 bytes corresponds with bigint (alias int8): signed eight-byte integer
