How to trim the first x characters of an attribute
  • Aug 3, 2017 8:32 AM UTC
  • 7 replies
  • 1515 views
Hi there,
the sample attribute looks like: "xxx www.mypage.com\\\\localserver.com"
Between the "xxx" (the number is variable) an the URL is a blank. So I need to find the index of the first blank and trim the attribute (string) from left to that index.
In addition I need to remove every character including an beyond "\\\\".
Any hints? I think it will work with the StringSearcher or StringReplacer...but actually I have no idea .. :-((
Thanks in advance,
Stefan
Best answer by takashi
Hi @stefangiese, the StringReplacer could also be used here, with these parameters.
  • Mode: Replace Regular Expression
  • Text To Replace: .+?\\s+(.+?)\\\\\\\\.+
  • Replacement Text: \\1
pratap
Forum|alt.badge.img+12
  • Aug 3, 2017 8:35 AM UTC
Attributesplitter.
You can split the value based on space
Forum|alt.badge.img+54
  • Aug 3, 2017 8:44 AM UTC
You could use a regular expression in a string searcher
e.g. something like (?<=\\s).+(?=\\\\\\\\) to return everything from the first space up to \\\\
Yup, worked fine... :-) Thanks...
BUT - in addition - I have a similar structure on a different attribute containing names. The attribute looks like "xxx Kindergarten Sunflower".So I need to trim "xxx " an keep the rest of the attribute. With the attribute trimmer I "cut" even the portion I want to keep. So it would be perfect to just trim the first characters incl. whitespace...
  • Aug 3, 2017 8:53 AM UTC
  • Aug 3, 2017 8:57 AM UTC
Updated the regex to support your new request.
  • Text To Replace: .+?\\s+(.+?)(\\\\\\\\.*)?$
  • Aug 3, 2017 9:00 AM UTC
This will trim from the first space onwards
Hi takashi,
yep, works perfect!! Thanks :-)))
