How to transform complex geometries to a single format - and save them as polyhedralSurface in postGIS
I have several IFC files, each one has its own structure.
I managed to save some of the data as a polyhedralSurfaceZ in postGIS, but some of the data structure is more complicated, and saves as a geometry collection of several types.
I only managed to save it to postGIS when the geom type is the general "GeometryZ" but then I cannot used the indexing power of postGIS and queries take forever, and some don't run at all ( like st_volume)
is there a way to transform the geometry collections to a solid that will be saved as polyhedralSurfaceZ?
example of such data:
GEOMETRYCOLLECTION Z (CURVEPOLYGON Z (COMPOUNDCURVE Z ((....
some also have PolygonZ , some have POLYHEDRALSURFACE Z
virtualcitymatt
Forum|alt.badge.img+36
I'm not exactly sure what you want, however, perhaps I can help
You probably wont be able to convert a collection into a Solid but you should be able to extract each solid from the collection(s).
A few tools which might help:
  • AggregateFilter (can be used to find aggregates (and maybe? collections)
  • GeometryFilter (in FME 2022 there are lots of options to get specific and can also be used to get rid of <null> geometries)
  • GeometryPartExtractor (Can be used to extract BRep solids directly out of Aggregates/Collections) super helpful
  • GeometryCoercer (Can be used to go from CompositeSurface to BRepSolid or Mesh)
thanks, I will try them
