How to submit a surface to Orientor? Since every triangle must be rotated.
  • Feb 11, 2022 1:58 PM UTC
  • 74 views
zilvinas_fme
  • Feb 11, 2022 4:07 PM UTC
Hi @zilvinas_fme​ , you can use Orientor to reverse the orientation of surface. Isn't it your desired function?
zilvinas_fme
  • Feb 14, 2022 9:12 AM UTC
Hi Takashi,
I started with Triangulator and received triangles used with GeometryCorcer to convert to fme_polygon.
But GeometryCorcer all results was "untouched".
  • Feb 14, 2022 9:56 AM UTC
Hi Takashi,
The feature output from the Triangles port of Triangulater has a MultiArea geometry which consists of multiple polygons, and GeometryCoercer considers it as a kind of polygon geometry, so outputs it from the Untouched port.
