how to split lines at certain point at intersection
  • February 25, 2020
  • 20 views
gogopotter90
Forum|alt.badge.img+13
Hello Guys ,
i want to split ths two lines that intersected in point, i have coordinates for each x maximum and x min. and y max. and y min ,
i know,one of them is xmax and the another should be in this case minimum
one also is ymax and another should be ymin
i used topology builder static to make group network id and it did correctly but this two lines i do not want to be in the same group
so i used clipper points as input and lines as clippe but i found it did nothing .bcs i used after that zopology builder static and it consider both of them in the same group and i want to give each one new network id
so is it possible , to make topology builder static with condition that create network id for all lines except the when it occurs value of x max equal value of x min ,value of y max equal y min .do we have conditional to write it for topology builder .
or could i use clipper to split two lines when x min value and x max are equal
y min is equal with x min .
danilo_fme
Forum|alt.badge.img+45
  • February 25, 2020
Hi @gogopotter90
Could you share your data?
Thanks in Advance,
arnold_bijlsma
Forum|alt.badge.img+14
I wouldn't go for a solution involving min-max values, as it would only work in specific cases, not in general.
Do the lines have any attributes by which you can distinguish the highlighted from the non-highlighted? In that case I would use a Dissolver.
Alternatively, do you have any point feature class for these intersections? (As a water engineer, it looks like an incoming an outgoing pipe to a pumping station to me)
  • February 25, 2020
@gogopotter90 LengthToPointCalculator and Snipper might be what you're looking for.
gogopotter90
  • February 25, 2020
Thanks alot ur idea is so perfect,u saved me
