How to set up the Query String Parameters in HTTPCALLER with a URL that ends with /1729/1774.mvt where the two numbers are variables in a CSV file.
  • Jun 2, 2021 1:26 PM UTC
  • 307 views
mikamattila
When using HTTPCALLER I cannot figure out how to use the Query String Parameters. The URL ends with /1729/1774.mvt these two number are in two columns in a CSV file (attached).
The whole URL is the one below and if I use that as a Request URL it works (its password protected).
https://maps-ver.lantmateriet.se/vt/fastighetsindelning/v1/wmts/1.0.0/fastighetsindelning/default/3006/10/1729/1774.mvtSkärmavbild 2021-06-02 kl. 13.52.41
  • Jun 2, 2021 1:31 PM UTC
If you need to render the two numbers dynamic, the easiest is probably to create an attribute with the URL based on concatenating the different parts together with the attributes containing these numbers.
Example:
httpcaller_urlA query string is something different altogether (it's basically everything that's after a question mark in the URL) , and based on your example it's not what you need.
