How to send form data through httpcaller transfomer?
  • Apr 17, 2023 8:48 PM UTC
  • 6 replies
  • 418 views
In Postman:
I have setup a POST request to https://xxx.com/login
In Body as form-data or x-www-form-urlencoded
username:user@test.com
password:Test123
And I get my response back OK
In my httpcaller I am setup like this :
attribute_creator_loginhttpcaller_configBut now I got a server error, just like my request is malformatted, as you see I even tried to put the form data into a specific attribute instead of passing directly inside the httpcaller. I got a feeling that fme httpcaller is having a problem with the "@" in the username, because in cURL I would put username in double quote to make it work just like :
curl -X POST -F "username=user@test.com" -F "password=Test123" "https://xxx.com/login"
What am I doing wrong there?
todd_davis
Forum|alt.badge.img+23
  • Apr 18, 2023 1:42 AM UTC
If it is form data you need to send. The easiest way is to change the "upload data" to "Multipart/Form Data" in the httpcallerimageSee how you get on.
Cheers,
Todd
Didn’t work either, but mocking the Api under Postman it worked, can’t figure out what is going wrong…!
todd_davis
  • Apr 18, 2023 1:58 AM UTC
Based on your curl input. In FME it will look like this.
todd_davis
  • Apr 18, 2023 1:59 AM UTC
Well I didn't put in the full request url. Missed the login bit.
  • Apr 18, 2023 12:09 PM UTC
Exactly what I did but except for my mock API under Postman it is not working for the production environment :(
danminneyatsaf
Forum|alt.badge.img+13
@newsafeuser​ you could try using the Use Authentication parameter at the bottom of the HTTPCaller as opposed to using an Upload Body. This will allow you to define a username and password. Let us know if this ends up working for you.
