how to select rows based on start and end values from previous rows
gcarmich
Participant
I have a table of values with ID, Start, and End. Starting with the first row, I need to select the next row where the start value equals the end value of the first row. I need to repeat this process for the entire table.
For example, I'd select row 1 then row 4 then row 6 then row 9 then row 13...
imageAny thoughts on how to do this?
Best answer by geomancer
You can accomplish this by looking at the attributes of the previous feature ('Enable Adjacent Feature Attributes'), and add some logic. Next step: keep only the features where Keep = 'Y'.
Start_is_End
geomancer
Forum|alt.badge.img+50
  • June 15, 2023
Start_is_End
gcarmich
Participant
  • Participant
  • June 15, 2023
Perfect! Thank you
