How to select a unique file in the dialog box of a parameter of a Spatial ETL Tool?
Hi everyone,
I have finished a FME Workbench and I wish to share it throughout my organization via an ArcGIS Pro Tool (Spatial ETL Tool). To create an ESRI Spatial ETL Tool, I followed this tutorial (Create an Esri spatial ETL tool—ArcGIS Pro | Documentation) and this specific section: “Reference an existing FMW file to an ETL toolbox”.
Through the user tool interface (as in the Geoprocessing pane), I would like for a user to be able to:
-         Define the output file name and the path where the file location.
==> Those two parameters work.
-         Select the unique input file in a Geotiff format (extension *.tiff)
==> Doesn’t work
imageTo do that in the FME Workbench (ArcGIS Data Interop. Workbench) --> Navigator (left panel) --> User parameters --> Right click --> Manage User parameter --> Insert new user parameter of type “File/URL” (trough the green cross) --> Click on the parameter to opens his settings à In File/URL Configuration :
  • Items to Select : Files
  • File configuration :
    • Path Selection : Single path (Impossible to select a file in the dialog box of arcgis pro)
    • Specify extension Filters : *.tif (Filter doesn’t show up in the dialog box of ArcGIS Pro)
User parameters setup in FME WorkbenchIn FME, when running the workbench everything works well. The single file source can be selected. However, in ArcGIS Pro, it is not possible.
So when I wish to run this workbench in ArcGIS Pro. I cannot setup the user parameter like I would like to:
-         It is impossible to select a file in the dialog box of ArcGIS Pro.
Click on the icon folder --> Select my input file --> click Open --> Instead of selecting the file, it open’s the file like a folder, and with nothing in it. And I can’t click Ok…
  • And the Extension Filter (*.tiff) doesn’t show up in the dialog box.
Filter files by extension doesn't work
Has anyone had this problem before? Any help is very welcome.
Thank you in advance :).
(I save each time I modify the setup of my user parameters in my workbench and I refresh the toolbox in the catalog pane of ArcGIS Pro).
rahulsharma
Forum|alt.badge.img+10
Hi @bdel​
Can you verify the Data Interoperability Extension version that you are currently using?
I think I can see the issue with your workspace in ArcGIS Pro 2.9, but like to verify if you are using the same version.
I did a bit more testing and it appears that some extension appears to be working such as *.mif / *.mitab but will need to investigate this further.
  • June 10, 2022
rahulsharma wrote:
Hi @bdel​
Hi @rahulsharma​ ,
I'm using ArcGIS Pro 2.9.2 and for the Data Interoperability Extension:FME InformationThank you for your help !
  • July 1, 2022
rahulsharma wrote:
Hi @bdel​
Hi @rahulsharma​ ,
Did you had time to investigate and find a possible solution?
Thanks in advance,
Ben
weihong
  • April 8, 2024
I had the same problem when try to get <string> or <field> user parameters from arcgis pro to the fme tool….feels like there are some bugs
