How to save inspector output as file to show the result any time without running the workspace again
  • May 20, 2020 8:36 AM UTC
  • 69 views
gogopotter90
Forum|alt.badge.img+14
could i save inspector as file that i can open it anytime ,i want to show the result without running again the workspace,
if yes, what is the method
  • May 20, 2020 8:42 AM UTC
In the Inspector you can use the Save icon, on the top-left of the toolbar.
If you only intend to open the resulting data with the Inspector, I recommend using the native FFS format. Using other formats may introduce modifications due to format limitations.
More info in the documentation: http://docs.safe.com/fme/2020.0/html/FME_Desktop_Documentation/FME_DataInspector/DataInspector/Saving_a_Dataset.htm
