How to rotate rasters around an arbitrary point?
  • December 17, 2014
  • 121 views
Hi All,
Is there a good way to rotate a raster around an arbitrary point (as you can with Vectors using the Rotator)? Because the docs say the rotator only allows rotation around the upper left corner of a raster.
Or failing that, does anyone know of a process I could put my features through to achieve the same result?
I suppose I can try Python, but that's always my last-resort.
Thanks,
Jonathan
Best answer by takashi
Hi Jonathan,
I would use the 3DRotator. Try a Custom Axis setting like this.
Angle in Degrees: <rotation angle>
Rotate Along: Custom Axis
Origin X: <x coordinate of the point>
Origin Y: <y coordinate of the point>
Origin Z: <any. 0 is OK>
Direction X: 0
Direction Y: 0
Direction Z: 1
Takashi
  • December 17, 2014
Hi Jonathan,
Direction X: 0
Direction Y: 0
Direction Z: 1
Takashi
  • December 18, 2014
Hi Takashim
That works like a charm. I'd never have thought to have used 3DRotator.
Many thanks,
Jonathan
