How to reveal line length in meters
gcarmich
Participant
I have two input table I set to LL-WGS84. I need to determine the length of the lines after the SpatialFilter in meters. I re-projected to XY-M then used LengthCalculator but the resulting values are not in meters. How do I reveal the line length in meters?
Forum|alt.badge.img+49
Can you try reprojecting to AZMED (Azimuthal Equal Distance) instead and see if that makes a difference?
  • June 5, 2023
There's also the GeographicLengthCalculator on the FME Hub:
https://hub.safe.com/publishers/safe-lab/transformers/geographiclengthcalculator
gcarmich
Participant
  • Participant
  • June 5, 2023
Ok. I tried that but ended up with the same results. Sample distance is 0.11609942923451384
