How to retrieve list with dissolver
  • November 26, 2013
  • 7 replies
  • 7 views
farfar
Forum|alt.badge.img+11
Hi all,
I look for ideas to retrieve all values of my attribute if the dissolver count has more han 1.
Example :
I have 3 shp with ("Name" and "Code" attributes). I connect there with Dissolver transformer (with Dissolver Count Attribute = "NB_Layer" and Liste_Name = "list_layers").
I need to add a new attribute with attributeCreator ("LIST_CODE") that contains :
list_layers{0}.Code IF  NB_Layer = 1;
list_layers{0}.Code "," list_layers{1}.Code IF  NB_Layer = 2; (concatenation of codes)
list_layers{0}.Code "," ... "," list_layers{N}.Code IF  NB_Layer = N;
Thanks an advance.
FarFar
Best answer by david_r
if you send the list to a ListExploder you can accomplish this with the regular (i.e. non-list aware) transformers.
David
  • November 26, 2013
David
  • November 26, 2013
If you need to concatenate elements of the list attribute, consider using the ListConcatenator transformer.
Takashi
farfar
  • November 26, 2013
Thank you for help. I use ListConcatenator transformer. it work but i have a doublons into my list. How can I deleted theme before used listconcatenator?
Thanks an advance.
FarFar
  • November 26, 2013
Try using the ListDuplicateRemover before concatenating.
farfar
  • November 26, 2013
Thank you Takashi, it works.
FarFar
  • November 26, 2013
Just a quick tip: type "list" into the workspace to see all the transformers that work on lists:
You can also look under "Lists" in the Transformer Gallery categories:
David
gio
Forum|alt.badge.img+15
  • November 26, 2013
Using exploder prior to removing "doublons" might add unescesarry amount of processing.
wen u do this on sets witch are listed on ltiple attributes and even more so when u have nested lists, explosions might yield an enormous amount of objects.
just a tip/reminder..
