How to retain ObjectID in GDB
  • Mar 29, 2021 8:27 AM UTC
  • 5 replies
  • 443 views
Hello. I am trying to make a transformation in the values of a certain field called Labeltxt in a feature type in a gdb. I change the value in the field. This succeeds, but when I need to write back into the gdb i have a problem:
Either i use "drop and create" in the writer, but then the objectID field is re-written, which we use to relate to other tables.
Or i use the "update" "use existing", and then select "labeltxt", but then the field is not changed in the gdb that is written.
Is there a way that I can retain the Object ID and also change the labeltxt value?
Regards Rasmus
Best answer by nielsgerrits
You need Update and Use Existing, and select ObjectID in Row Selection Columns.
2021-03-29_12h03_54
nielsgerrits
Forum|alt.badge.img+67
  • Mar 29, 2021 10:00 AM UTC
2021-03-29_12h03_54
  • Mar 29, 2021 11:11 AM UTC
Thanks, that did the trick :)
hkingsbury
Forum|alt.badge.img+73
  • Mar 29, 2021 11:01 PM UTC
While @nielsgerrits​  answer is correct, I would strongly recommend against using an ObjectID as a "unique identifier" as ObjectIDs change change. If the data is copied or moved between databases, the object ID might change. I'd reccomend have a seperate GUID type field setup that you can use for any relationships that may be required
nielsgerrits
I second this. I was assuming he had no other id field available.
  • Mar 30, 2021 7:01 AM UTC
Thanks for the advice. Yes, we realise that this was a mistake. But we have a massive database built on this system, so it is too late to change now unfortunately.
