How to replace special characters or symbol’s in attribute creator?
  • July 27, 2015
  • 38 views
parashari
  • July 27, 2015
Hi Mahendra,
You want to change the name of the schema or just the attributes? If its schema, you can go for AttributeRenamer. Else, if you are looking for the change in the attributes, StringReplacer is a good idea.
