How to replace characters(like A-Z) in a string with their corresponding ASCII codes(like 65-90) in bulk?
  • April 5, 2016
  • 5 replies
  • 74 views
fmelizard
Forum|alt.badge.img+22
  • April 6, 2016
Hi @FMEZipster, you can use the TextEncoder (Encoding Type: HEX) to translate every character within a string to ASCII code with hexadecimal representation.
If you need to convert the result to decimal representation and/or comma-separated format, need some additional transformers or other approach. What representation do you need finally? e.g. ABC -> ??
  • April 6, 2016
Decimal representation(e.g. ABC ->656667)
Decimal representation?e.g. ABC ->656667?
  • April 6, 2016
  • April 6, 2016
This is a possible way - split the string into individual characters, extract their ASCII code (CharacterCodeExtractor), then concatenate them (Aggregator).
... scripting might be easier in this case.
PythonCaller script example:
def extractAsciiCode(feature):
    codes = [str(ord(c)) for c in feature.getAttribute('_src')]
    feature.setAttribute('_codes', ''.join(codes))
TclCaller script example:
proc extractAsciiCode {} {
    set codes {}
    foreach ch [split [FME_GetAttribute "_src"] {}] {
        lappend codes [scan $ch %c]
    return [join $codes {}]
  • April 8, 2016
It works. Thanks a lot.
