How to remove the intersection of a road in fme?
  • Jul 6, 2022 4:59 AM UTC
  • 96 views
The input looks like this:imageThe result must look like this:
Best answer by ebygomm
This sort of process, with a group by on the dissolve should ensure you have no gap, the tricky bit is to work out so the group by dissolves the overlap into the correct road segment
imageThat gives me this sort of result
image from a starting point of this
Forum|alt.badge.img+54
  • Jul 6, 2022 8:30 AM UTC
I would use an area on area overlayer to separate the overlap, then dissolve the overlapping segment back into one of the roads. You will probably need some logic to ensure you dissolve back to the correct road segment.
I tried that way and the result became like this. Is there a way to fill that gap? Could you share the parameters of the transformers used?image
  • Jul 6, 2022 8:58 AM UTC
The parameters in mine are shown like this.imageAnd for grouping I dont have the option that you have.image
