How to read Esri FileGDB without Feature Class "names" / schema-prefix
  • Mar 16, 2023 12:23 PM UTC
  • 83 views
reservoirdog
Forum|alt.badge.img+12
I have several Feature Classes in a FileGDB and would like to convert these into a Geopackage. Therefore I would like to remove/not read the different schema-names / Schema-prefixes.
A Feature Class "WAS_LABEL/WAST_TEXT" would be read as "WAST_TEXT" without the schema-name/prefix.
Is there an easy way to achieve that?
The FeautureClass-Names in the geopackage need to be "flat" without schemanames...
  • Mar 16, 2023 12:59 PM UTC
One solution could be to use a StringReplacer with the following regular expression, replacing it with an empty string:
reservoirdog
  • Mar 16, 2023 1:05 PM UTC
Thanks David,
preferable would be a checkbox at the Reader like at the "SQLite" Reader "remove table qualifier", but I guess there's not such an option. Using your method, I would need to manually change each feature type one by another, or can it be done using a feauture reader and then the Stringreplacer on the featuretypename attirbute?
Thanks David,
@reservoirdog​ FME doesn't really treat the feature dataset as a table qualifier. If you can use the File Geodatabase (ArcObjects) reader then the feature dataset is handled slightly differently.
