How to put the StartValue of a joined Line into a MeasureGenerator?
  • Nov 23, 2018 5:22 PM UTC
  • 83 views
cheffing
Participant
I try to repeat this sample of LRS-Tasks on my data:
Probably a beginner-question:
How can I set/transfer the attribute 'von_km_l' as startvalue in my MeasureGenerator? After the
five line segments are joined in one NLE(network linear element), I got the attribute on the treats:
As you see, the needed value is avaliable within the trait-attribute. But how to set it
as startvalue in the MeasureGenerator?
Thanks and best regards from Berlin,
Christoph
  • Nov 23, 2018 10:08 PM UTC
You can populate the attributes of the original lines into a list attribute by specifying a list name (e.g. "_list") via the List Name parameter in the LineJoiner. Then, set a list element storing your desired value (e.g. "_list{0}.von_km_l") to the Start Value parameter in the MeasureGenerator.
If you have measure from (von_km) and measure To (bis_km), then may be you can use measure setter
