How to put columns in Excel output in another order?
  • Jul 17, 2023 10:46 AM UTC
  • 9 replies
  • 195 views
Hmm, I am struggling with this for a day now and I tried the tutorials, but it seems I am doing something wrong.
So, basically I have an xml file out of which I want to put certain elements into an Excel output. But here is the issue.
I want those outputs in a certain order - and no matter what I do, FME will always write the columns into alphabetical order. Which just will not do for this application.
The transformation is a simple one:
transformation
But somehow I always end up with the same output.
As You can see, I already renamed the attributes with the numbers, trying to sort it that way, but no matter what I do, the output then looks like this:
output(Also with those weird widths for those columns)
Can this be somehow changed?
Thanks so much in advance.
Forum|alt.badge.img+63
Can you post a screenshot of the User Attributes part of the feature type properties?
  • Jul 17, 2023 11:13 AM UTC
Sure! This is what it looks right now:
Reader
input
Writer:
  • Jul 17, 2023 11:14 AM UTC
Sure.
Reader:
Writer:
Reader
input
Writer:
Switch it (on the writer) from Automatic to Manual. Depending on what you're doing in the AttributeManager you may have to map the attributes though.
  • Jul 17, 2023 11:17 AM UTC
Thanks I will try that.
Okay, uhm, now it is throwing me this error:
Check if the parameter 'Use Attribute Names as Column Position" is set to yes. It should be no.
  • Jul 17, 2023 11:36 AM UTC
It runs through now, but somehow it still writes the columns into the wrong order. :( This is what my parameters look like right now:
I've you've written before and are not overwriting the file (check the Navigator) then that is indeed what will happen.
So try removing the file and run again (and consider whether you need to write a new file every time the workspace runs or append to an existing file)
  • Jul 17, 2023 11:49 AM UTC
Ah, thank you. I have overseen that. Thanks!
