How to process many .dwg files
  • Mar 11, 2020 4:10 PM UTC
  • 0 replies
  • 61 views
I need to combine the attached drawings following this procedure:
  • drawing A contains geometry);
  • drawing B contains some attributes defined in AutoCAD with the ATTDEF command, but doesn't have any geometry features
How can I build, inside FME, the drawing C using the geometry stored in drawing A and the attributes defined in drawing B?
How can I extend this kind of workflow to have in input an entire directory (in which there are hundreds of .dwg files) instead of a single drawing A?
So far I tried toconnect directly a reader and a writer, setting drawing B as template file but it didn't work.
Thanks for your help.
