How to populate GDB_GEOMATTR_DATA with FME?
  • Jan 17, 2023 2:08 AM UTC
  • 150 views
arthy
Forum|alt.badge.img+8
I would like to import Autocad(.Dwg) file data into an Azure SQL table.
In this table, I have the field GDB_GEOMATTR_DATA wich is populate by ESRI (Arcgis Pro) to store complex geometries.
How can I populate such GDB_GEOMATTR_DATA field with FME? I tried to use the geometryExtractor transformer but it's not working.
@Takashi Iijima​, @jdh​, @Hans van der Maarel​ and others, any thoughts?
Thanks,
paalpedersen
  • Jan 17, 2023 6:24 AM UTC
To make it simple. You need FME with arcgis enterprise extension. Then You can use the ArcSDE writer.
This extension requires:
Windows,
Arcgis Pro, or Arcgis Server or arcgis desktop with 64 bits background processsor on the same machine.
