How to perfrom Intersect in FME. I would like to get the duplicated results if the line falls within two buffersreas.
  • Sep 27, 2019 4:29 PM UTC
  • 66 views
ArcGIS Intersect gets the exact result I need, but this task needs to be performed in FME. I haven't been able to find the exact output result. With Spatial Filter it did not duplicate the results if the same line fell within two or more buffers, it would only grab it once. Below is an illustration of what I would like to achieve. Also, of course, I would want this to produce an excel report on which buffers intersected which lines
Forum|alt.badge.img+54
  • Sep 27, 2019 4:42 PM UTC
Try the SpatialRelator instead of the SpatialFilter. The relationships will be stored in a list which you can explode if necessary to get separate features for each overlap
