How to perform Z-value shift on Triangulation in dxf format
  • Feb 11, 2019 2:14 PM UTC
  • 49 views
e_nmn382002
I am performing a reprojection on triangulation (in dxf format) to a custom coordinate system. However I still need the Z values shifted by 2000 metres, which is not covered by the reprojection. How can i approach this? Do i need to extract all vertices?
Forum|alt.badge.img+63
If it's a simple shift you can use the Offsetter.
