How to obtain a proportional spatial sum using multiple clippers ?
  • Oct 18, 2021 12:21 PM UTC
  • 43 views
Hi FME community,
I'm creating a workspace to automate a proportional spatial sum.
I have polygons with employment data.
And I have bus stops that I'm using to create multiple buffers as my zones of interest.
I'm testing this with zones I've already caculated with MapInfo GIS software so I know what values I'm suppose to have in the end, and i'm able to compare this with FME workspace results.
I get the expected result when I aggregate all my stops points from all buses indifferently:
proportional spatial sum_all_stops
But I also need those stats for each bus separately. To do so, instead of aggregating indifferently all points, I do it with a group by using my bus name attribute.
But the results are way off.
proportional spatial sum_by_bus
If I add a tester before the buffer, in order to filter only one bus, I have the exact result. As soon as there is more than one zone of interest the results are false.
My guess is that I don't know how to use the clipper correcly with multiple zones as clippers (even if the clipper type is on "multiple clippers").
Any ideas or other method to accomplish this ?
Thank you for taking the time to read this
itsmatt
Forum|alt.badge.img+48
  • Oct 18, 2021 5:31 PM UTC
I'm not 100% sure that I fully understand the process​ or the problem but could this be related?
The total input area of the clippees usually matches the ​total output of the clipped area. Meaning that none of the output clipped areas should overlap.
If some of the clippers​ overlap you might get unexpected results.
At least this has been my experience. Perhaps the AreaOnAreaOverlayer might give you better results?​
