How to merge line segments?
  • Nov 27, 2017 4:04 PM UTC
  • 6 replies
  • 505 views
I have this topology and would like to merge the red segment with its corresponding blue segments. (Blue segments are on both side of the red segment.) I can group all red and all blue segments but I haven’t an attribute to group the related blue and red segments. Is there a way to do this with FME? Thank you for the help.
Best answer by takashi
Hi @nindalf, if red line and blue line which should be connected are definitely touching each other at their end nodes, this workflow might help you. Assuming that the blue lines have unique ID attribute. If they don't have unique ID, you can add temporary ID to them with the Counter.
erik_jan
Forum|alt.badge.img+26
  • Nov 27, 2017 4:06 PM UTC
I believe the LineCombiner transformer should be able to help.
danilo_fme
Forum|alt.badge.img+58
  • Nov 27, 2017 7:43 PM UTC
I agree with you !
  • Nov 28, 2017 6:09 AM UTC
Ok, this is a good start but I’ve the problem that this transformer connects also segments within the red and the blue group. But it should connect just a red segment with segments form the blue group. Is there a way to specify this?
  • Nov 28, 2017 6:32 AM UTC
  • Nov 28, 2017 6:48 AM UTC
Forgot to add an annotation about this parameter the SpatialFilter.
  • Spatial Predicates to Test: Filter Touches Candidate
  • Nov 28, 2017 3:39 PM UTC
Thank you for the example. It seems to work like this.
