How to load data from one table to another table
  • Sep 26, 2019 11:10 PM UTC
  • 6 replies
  • 329 views
Hello Friends,
Since I am learning new transformations and new to FME tool. Could someone please guide me how to load a data from one table to another ( 100% dump)? which transformation to use? I use SQL executor when I wrote Select * from table1 and mapped result output to Writer.
Is there any other way? Thank you in advance!
I have used above two transformations but it took 5 mins to load 280K rows. Can I make it faster by using different transformation?
See below..
Also, the transaction Log says.. " Feature caches have been recorded at every state of the translation"
Is this slowing down the process? can I disable this feature? if yes, How to fix it?
Thank you!
itay
Forum|alt.badge.img+19
  • Sep 27, 2019 5:43 AM UTC
Depending on the FME version, you should be able to disable feature caching from the menu.
oscard
Forum|alt.badge.img+23
  • Sep 27, 2019 6:04 AM UTC
Once you are more comfortable with the tool and if you are going to do that with many tables, you should check the Dynamic Workflows:
https://knowledge.safe.com/articles/1050/dynamic-workflow-tutorial-introduction.html
Hi Oscard, Thank you for replying. I have a source table in One Oracle DB and Target table is already created in another oracle db. I just need to dump data from source to target. I just did below but features ( records) are not being inserted in target table. Could you please help me here? what am I doing wrong? Also, I don't see the columns names for Target table, the same I see in source. please help? Thank you.
Thank you Itay for replying. I have a different version of FME installed but I was able to find it how to disable it.
Also, the ultimate goal is to load data from A.table1 to B.table2 ( from table in schema A to table in schema B). Both schema & table name are different in different database ( both oracle) though.
