How to let the BulkAttributeRenamer do substring?
nielsgerrits
Forum|alt.badge.img+54
Is it possible to do a substring(0,10) with the BulkAttributeRenamer? I want to simulate truncating the columns as writing to shape does. I know I can do this with a SchemaMapper, this is my current workaround.
Best answer by david_r
You can use the regex replacement method. For example, this will truncate all attribute names to the first 10 characters:
  • March 26, 2018
Hi @nielsgerrits, yes it's possible. Try this.
Text To Find: ^(.{10}).*
String: \1
  • March 26, 2018
  • March 26, 2018
String: \1
You beat me to it! :-)
nielsgerrits
String: \1
Thanks! I knew it should be doable but gave up after a few tries.
nielsgerrits
Thanks for the effort!
