How to iteratively merging rings
  • May 4, 2018 9:25 AM UTC
  • 60 views
chau
Forum|alt.badge.img+8
I have a set of polygons resembling the Towers of Hanoi (I have many towers with varying rings but only included one tower here):
I would like to start with the polygons which doesn't have any holes and which are holes in other polygons (in this case I only have the small one in the center) and dissolve it with the polygon in which it is a hole. I would like to repeat this until the dissolved area is larger than some threshold (here 30).
Can I do this in FME 2016?
I have attached a shape file with the data set above.
  • May 4, 2018 10:58 AM UTC
The Dissolver can dissolve those rings at once and form a single large polygon. Why do you need iteration?
chau
  • May 4, 2018 11:17 AM UTC
I need it because of the combined dissolved area threshold, at least I think I need it.
  • May 4, 2018 11:45 AM UTC
Hi @chau, if all the rings are donuts, remove hole from them, calculate area for each, then select one which has the maximum area within the threshold. I think it would be your desired result. This is an implementation example.
