How to insert large payload to Orcale Database table
Hi Folks,
we are trying to save json request/response data into oracle database using SQLExecutor and getting following error
java.sql.SQLSyntaxErrorException: ORA-01704: string literal too long
Request that we are trying to save is more than 6000 characters. Appreciate your suggestions ?
Best answer by david_r
tanveerafzal wrote:
Oracle Database column type is CLOB. for Writer i am using insert statement using SQLExecutor. oracle database is 19C.
When using an SQLExecutor, the CLOB is actually transmitted as a string literal, which is why you're running into this Oracle limitation. Remember that the SQLExecutor simply transmits the entire SQL statement as a string to Oracle, there is very little or no parsing being done by FME.
If possible, I would look into using either a FeatureWriter or a DatabaseUpdater to insert the actual CLOB value, those should be much more intelligent in how they handle LOB datatypes.
  • June 30, 2021
What is the Oracle datatype of the field you're writing to? How is the writer data type for the same field configured?
  • June 30, 2021
Thanks David, DatabaseUpdater as able to save the CLOB data. Appreciate your help.
I had a similar problem some years ago. Solved using cx_Oracle (Python).
