HOW to insert EXCEL data in EXCEL TEMPALTE keeping or having 1st two rows same in output.
  • May 26, 2022 9:28 AM UTC
  • 66 views
magi
FME workbech
workbenchREADER (raw excel file)
Raw excel file
TRANSFORMER
counter setting
WRITER ( Desired or Expected RESULTS) SETTING
1st row is merged
2nd row id columns names
I want the data to be inserted / updated from ROW 3 keeping the first 2 rows same.
Note : Everytime i run FME the number of ROW records will change so results should dynamicaly upated and NO APPEND .
DESIRED output
WRITER SETTINGS
writer setting
TEMPALTE : Template
magi
  • May 26, 2022 9:31 AM UTC
If shall be highly thankful to your help or support :)
  • May 26, 2022 2:27 PM UTC
Hi, how to use formula finde?
@magi​  Have a look at the example on this question
magi
  • Jun 22, 2022 8:35 AM UTC
thank you all for ur help and quick support :)
