How to get such information as the size and the last modification time of a file?
  • April 15, 2016
  • 49 views
I want to get such information as the size and the last modification time of the source file. Any transformers or methods?
  • April 15, 2016
Hi @flanco, the Directory and File Pathname (PATH) reader might help you. Set "YES" to the "Retrieve file properties" parameter of the reader to retrieve file properties including size and modified time.
  • April 19, 2016
Constructive suggestion.Thanks!
patrick_koning
Forum|alt.badge.img+7
Hi @flanco in fme 2016 with the FMW reader you can read the fileproperties.
