How to get current Z value in 3DForcer?
  • January 24, 2017
  • 143 views
Hi everybody,
I am gonna use 3DForcer to reduce Z values of all points of a feature.
I have a MARK_Z value attribute and need to use Arithmetic Editor so that resulting z value becomes as z - MARK_Z. (z value of every single point of a feature minus MARK_Z attribute of that feature)
But I cannot get current z value in Arithmetic Editor. Any suggestion?
Thanks in advance!
Best answer by redgeographics
You can use the CoordinateExtractor to grab the z-value of a vertex and store in in an attribute, which can then be used in the Arithmetic editor.
However, the Offsetter might be better suited to what you're trying to do.
Forum|alt.badge.img+63
Thanks a lot man! That was PIA for a month!!
You're welcome! Happy to help :)
itay
Forum|alt.badge.img+19
  • January 24, 2017
You can use the ZValue directly in the Arithmetic Editor.
