How to filter point cloud based on dynamic attribute values?
  • Nov 6, 2017 10:53 PM UTC
  • 142 views
I tried looking for similar queries but I need some help with this asap. To explain my question further, I have a point cloud with x, y, z and the fourth column is a componentID (after having done connected components) I have a text file which consists of a string of component ID values.
I am trying to filter the point cloud based on the number of component ID values in my text file. So, I have a couple of questions.
1. I am trying the basic method by filtering the point cloud based on the value of the component but I keep getting the following error
PointCloudFilter(PointCloudEvaluationFactory): Attribute 'C1' is specified in an expression but is not present on the feature. Please ensure the feature has all referenced attributes
I am not really sure how to solve this. Because if I use an attribute creator to assign values to C1 independent of the values from text file, it works fine. But when I integrate it with text file it goes into error.
2. My text file will not always contain 3 values. It will vary. How do I make my workflow such that my point cloud is filtered dynamically according to the number of values in my text file.
I guess this is too specific hence I have attached a template file. I have been struggling with this the last 2 days and really appreciate some help!
Thank you
Best answer by daveatsafe
Hi @sraapril,
In order to put the text file attributes onto the point cloud, you must explicitly merge the features using a FeatureMerge transformer. I am attaching a modified workspace illustrating how to use this transformer with an indiscriminate merge.
pointmatch2.fmw
daveatsafe
Forum|alt.badge.img+24
  • Nov 7, 2017 12:44 AM UTC
Hi @sraapril,
pointmatch2.fmw
  • Nov 7, 2017 9:18 AM UTC
Hi @DaveAtSafe
Thank you very much! This works exactly like I want it to for my question 1.
Is there a workaround for question 2? I need to filter my point cloud based on all the values from the incoming list. However it is dynamic. Is there a way to code for the expression in point cloud filter?
Sravanthi
daveatsafe
  • Nov 7, 2017 6:04 PM UTC
Hi @sraapril,
For question 2, we can do this if we modify the text file into a proper CSV file, with columns for the point_source_id and matching classification.
I created a new CSV file in a text editor, in the form:
point_source_id,classification23450,622685,723949,8
I then changed the workspace to use a PointCloudSplitter and ListSearcher to apply the classification from the CSV.
Please try the attached workspace.
pointmatch3.fmw
las-py.csv
  • Nov 7, 2017 9:07 PM UTC
Hi @sraapril,
pointmatch3.fmw
las-py.csv
@DaveAtSafe
You are incredible! I was working on making my having a text file in the format you just have used. Now you built the workflow further. WOW!
Thank you very much! :D
