How to filter "latest" date attribute?
  • December 7, 2015
  • 522 views
Hi all,
in a SDF file, i have a date field and I would like filter/extract the record(s) with the latest date. What transformer/parameter should I use?
eg.
ID, DATE
1, 12-13-15
2, 12-13-15
3, 12-01-15
4, 08-01-14
5, 04-01-13
I would like to extract/filter ID 1 and 2 (records with the latest date) in this case.
thank you!!!
W
erik_jan
Forum|alt.badge.img+26
  • December 7, 2015
I would use the StatisticsCalculator to get the max_date in an attribute. Make sure you connect to the complete output port. You may have to use DateFormatter if the date fileld is of a string type instead of an actual date.
Then you can use a Tester to test if data = max_date.
That should give you all features that carry max_date as a date.
  • December 8, 2015
Two minor reminders:
- DateFormater over writes the original date so you might want to use AttributeCreator to copy the date first.
- make sure you create the format YYYYMMDD
(format string %Y%m%d) so that StatisticsCalculator actually finds the correct maximum date.
