How to extract IFMEPolygon properties ?
  • May 2, 2023 5:11 PM UTC
  • 5 replies
  • 114 views
vimva679
Forum|alt.badge.img+11
I would like to extract 'Orientation' >>
Plz any idea what setting i use so that i could see those value in table in filter the data according. imageimage
Best answer by dustin
Thank you, I tried that as well too but it does not output Orientation Left hand rule or Right hand rule . As this is only the filter that seperate polygon from other objects . So please if u know workaround
That is odd. What version of FME are you using? I'm using a beta version of FME:23, and it seems to extract the orientation. image
dustin
Forum|alt.badge.img+36
  • May 2, 2023 6:58 PM UTC
The OrientationExtractor should do this for you.
vimva679
  • May 2, 2023 7:05 PM UTC
dustin
  • May 2, 2023 7:13 PM UTC
vimva679
  • May 2, 2023 7:16 PM UTC
FME 2022
vimva679
  • May 2, 2023 8:03 PM UTC
great news this did the job with 2022.2 FME version . A little work around / tnx image image
