How to extract from feature class those entries that have a single value based on one attribute?
  • Nov 27, 2017 4:39 PM UTC
  • 155 views
I have a line feature class (with a field SURVEY), which I want to separate into 2 feature classes. In the first one I would have those features that have more than one feature with the same value in the field SURVEY - and in the other one - those features that have a single entry for a value in the field SURVEY.
I believe I could explode the original Feature class by the value in the SURVEY field, then count features in each of them, then test for value "1" and merge if required. But I don't know how to create separate features based on the value in the field.
Just to give you a context: For the first one I will later create convex hulls based on field SURVEY, but for the other one - buffers (as the convex hulls wouldn't look too good for a single lines). But this is not part of the question - as I know how to do it.
Please advise.
Best answer by jdh
If the number of features with the same value are irrelevant (just 1 or more than 1) I would use a Matcher (No geometry, Attributes to Match: SURVEY).
If the number of features in each survey group is relevant, I would use an Aggregator, group by survey, with a count attribute set.
jdh
Forum|alt.badge.img+41
  • Nov 27, 2017 4:56 PM UTC
  • Nov 28, 2017 10:19 AM UTC
Thanks @jdh. Matcher worked great.
