How to extract certain parts from path name ?
lifalin2016
Forum|alt.badge.img+30
I'm looking for a best practice to extract parts of a path name.
If I have a path: S:\\Miljø og teknik\\Svendborg Vand\\Anlæg vand\\Microstation\\Dokgraf dokumenter\\VandGraf\\vand_knude\\ULB00004\\Arbejdsrapport.pdf
I need to extract the part starting with "VandGraf", i.e.: "VandGraf\\vand_knude\\ULB00004\\Arbejdsrapport.pdf" into one attribute, and the file name into another.
What is the simplest way to accomplish this (without custom Python coding) ?
Cheers.
Best answer by ebygomm
String searcher with some regex possibly depending on the exact rules you want to follow, e.g. do you need everything always starting with VandGraf or everything at that level which sometimes might be in a folder not called VandGraf?
If the latter, finding the substring after every 6th backslash might be more straightforward e.g.
Forum|alt.badge.img+39
  • August 22, 2017
  • August 22, 2017
Have a look at the FilenamePartExtractor transformer also
robert_punt
  • August 22, 2017
You can also use an attributesplitter. Splitting on the '\\' but it has to be in the same place in the list.
lifalin2016
  • September 1, 2017
Actually, I wanted the former: everything starting with "Vandgraf", or NULL if not found.
lifalin2016
  • September 1, 2017
Alas, I can't be sure that the paths are that well-structured.
lifalin2016
  • September 1, 2017
I did, but it just gives me the "standard" parts of a path name, not a custom and optional part.
lifalin2016
  • September 1, 2017
I ended up solving it with a PythonCaller:
def processFeature(ft):
    doc_name = ft.getAttribute("Documentname")
    if doc_name != None:
        try:
            p = doc_name.upper().index("VANDGRAF")
            if p > 0:
                RelDocName = doc_name[p:]
                ft.setAttribute("RelDocName", unicode(RelDocName))
        except:
            pass
        pass
    pass
lifalin2016
  • September 1, 2017
        try:
            if p > 0:
        except:
            pass
        pass
    pass
The try-except was necessary, as it apparently throws an exception if the substring isn't found.
  • September 1, 2017
Even easier then with regex VandGraf.+ in the string searcher
