How to expose/use attachments from json
  • Mar 23, 2020 12:43 PM UTC
  • 194 views
Hi
I have a workbench looking at a json feed: https://niord.dma.dk/rest/public/v1/messages?lang=dk&domain=niord-nm
The feed contains attachments for some of the features, with a column specifying a link to the location of the attachment (PNG file typically):
I would like to populate a field with this url, so that I can sent it to correxponding features in a SDE database. i tried to use AttributeExposer and AttributeCreator to extract the link to a new coloumn, but this seems impossible as the coloumns with the attachment information is not available in the list of attributes to expose/create (should be between areas and charts):
How can I extract the information from attachments coloumns to an attribute in FME then?
Here is an example of one of the attachment files:
https://niord.dma.dk/rest/repo/file/messages/e/f0/ef03d235-70af-44e9-8a20-8c506534abfe/80/Overview%20with%20national%20measures_5.png
Best answer by ebygomm
If you wanted to expose attachments{0}.path you just type it in the AttributeExposer, it won't appear in the drop down. This is a list item though, so if you want to get all the values you will need to explode the list or similar.
Forum|alt.badge.img+54
  • Mar 23, 2020 1:00 PM UTC
daraghatsafe
Hi @kristianbj were you able to use the AttributeExposer to achieve your goal?
